dana 30 carrier break
Mitchen
Gresham, OR
i searched and found that the carrier break for a dana 30 is 3.54 and down and 3.73 and up.
i have 3.55 gears right now. 30/c8.25
im planning on regearing within the next summer and can get a trashed LP 30 axle with CV shafts and 3.73's out of a ZJ
will the carrier from that axle go into my LP 30 that came out of a 2000 xj that had ABS?
and will a carrier from a LP axle go into a HP housing
just wanted to get some answers from someone with experience
Thanks,
Mitch
To answer your question.. YES it will fit. But why the heck are you gonna regear a LP D-30? With the amount of HP 30's that are out there. Why not just find one of those with a 3:73 carrier and re gear that one, swap it in?
well i am planning on getting a HP 30 but if the carriers are interchangeable between HP and LP housings i was going to regear then swap everything to a new housing later.
thinking about it, it would probably be easier to just start with a HP 30 ha. are LP/HP carriers interchangeable?
all stock 30 shafts are 27 spline so i could put my ABS shafts from my LP 30 in a HP?
its an 88 and PO had thrown a LP in there i knew i was going to have to replace it when i bought it
thanks!
