danny Benavidez
- Texas
1. If you are buying ethanol mix, expect to lose up to 10% of MPG.
I got a 2001 and the above statement is very true
ummmmm.....this needs to be explored a bit. The engine should run smoothly in all conditions, all engine temperatures.
So it runs rough on startup periodically but ONLY when engine is cold? Never does this when the engine is hot? Do you ever notice extended crank times (having to crank longer than normal) when the engine is cold?
Do you currently have or have you ever seen a check engine light? If so, you have stored codes which should be pulled with a code reader or a scan tool for guidance, then post the exact code numbers here for comment.
Like once a month if that, on a startup either hot or cold, mainly hot, it will missfire (run rough), if I rev it a little it usually doesnt go away unless i do that for a minute or so, but if I go ahead and just drive it it goes a way in like 30 seconds or less. And when motor is cold she cranks up no problem everytime.
I meant search, not soak.Soak for heat soak on here.
Cali vs 49 state differences are in the exhaust manifold and catalytics I believe. If it says one or the other, you probably need the ones they specify. Bosch pretty much invented the O2 sensor, so I stick with them personally, since they are pretty fairly priced.Will a faulty o2 sensor trigger a check engine light? I guess you need 2 new sensors for upstream on a 2000. Any brand O2 sensors better than others? The build sheet form Chrysler said mine has California emission and rockauto.com has different ones listed for Cali and non-Cali emissions. Does it make any difference which one you get if you aren't in Cali? I don't really know how Cali emissions is different than non-Cali.
