Spaz_Soldier
- Winchester, VA
I've got a '01 XJ on 35"s as my daily. I'm thinking of regearing and possibly getting lockers. What does everyone think I should re-gear to and/or which lockers to get? Thanks in advance.
Thanks a lot, guys. Where can I find prices for the OX locker?
not to hijack or anything but i was wondering this same question but for 33's and a lot of highway driving
The gear selection isn't that straightforward. 4.56, while adequate at low elevations in flat terrain, will leave you wishing you had gone that extra mile when you hit hills, especially with 35". Personally I run 4.88 and 33's, but I am at high altitudes with hills.
Awe, common now, while where I live the Elevation might get as high as 50 feet we Do have 30 foot Inclines we have to climb every once in a while. LOL :sunshine:arty:
iratefla:
As for lockers, it's all in what you can afford. Selectable at least in front is advisable if you have the means. Also, while the Ox is a sturdy unit, wires and hoses are easier to run than cables, and easier to repair. Having to have Onboard Air is an additional cost, but has additional benefit. Everything has a trade-off.
For those who do like Air Actuated Lockers. Ox also offers an Optional Air Actuation System.
As I stated, I have driven in Heavy Rain here in Florida and the Oil, Grit, Rubber, Sand have kept me going straight without a Locker (That's on the Road and No Locker)... heaven forbid I had a LunchBox in the Front.
Detroit, Lockright, or Aussie (in that order) for the Rear.
I have an Aussie in the front of my daily driver and live in Oregon where it rains half the year. I've never had any problems going straight (or turning) on wet roads, mud, gravel, dry dusty dirt...
Does your Aussie in the front click while making turns in 2WD?
That is good to know. I will also say that I have never thrown the lever, and not felt it engage.I'll wait patiently for the OX locker fanbois to come and talk about all of the potential points of failure, positive engagement etc., but not once have I hit the button, thought i was engaged, and wasn't.
Why? The diff cover is pure beef; it can easily take an abuse, and is probably more heavy duty than many covers out there.oh, and i like having a diff cover that isn't an integral part of the system.
I'll start off by saying I run OX front and rear.
I will agree with you, everything does have a trade off. With ARB you have the bonus of onboard air, as well as those wires and hose is probably easier to run than the cable. With the OX, you have a heavy duty diff cover, you don't have to run extra wires, or buy and find a place and mount an air compressor. The stiffness of the cable is the main drawback in mounting it. They both have the pro's and con's.
But I will say that it is not easier to repair an ARB on the trail. If both lockers still function, but only the means of actuating them fail, then a bolt screwed into the OX cover will lock the locker.
With an ARB, a torn line will take time to replace, an air leak could take a long time to track down, and possibly even mean pulling the cover. Both an air leak, and an electrical failure with the pump would leave no means of actuating the locker, as air is needed.
