muddeprived
- PA
You can always do the warn hub conversion. It is pricey but it's serviceable and bearings are like $40 or so.
You can replace your unit bearings 5 times or more and still have paid less then the hub conversion.
Like others have said make sure the axle nuts are torqued properly. Timken is as good as anything else out there.
You weren't supposed to mention that! :twak:careful John, part of your gov't informant relocation program insists that you never publish past life experiences. dont you remember when they said next time you will have to be relocated to downtown LA? thats worse than syberia.
now back to the unit bearings... has anyone come up with a heavier duty one that can be machined down a bit to fit? im sure the center splines are used in alot of other applications.
