CAJJ93XJ
- Roseville, CA
hey I have an aussie locker stuck inside it carrier. the pin is welded to the carrier (thanks OP) and it's got a 4.88 ring bolted to it. great for someone who is about to regear their D30. the ring comes with it, free let me know if you don't want it
also I have a complete HPD30 housing. 4.88 gears, aussie locker still installed in it. I was told the pinion is chewed but I haven't looked
it has stock shafts, stock knuckles, brakes, etc. I used it as a parts axle and took all the goodies.
it has aftermarket coil buckets, LCA brackets, set up for 3 link with over axle panhard, johnny joint inserted in driver side upper mount, pass upper cut off
let me know if you want it I'll take $300 for the entire setup
Jake 916-847-0538 I don't really want to ship anything.
