Renix heads and intake manifolds have bigger intake ports, so putting a newer head and still using the renix intake manifold will work, but will not be optimal, cause some of the air coming in will hit the side of the head and create turbulence(renix ports are 1/4" lower on the bottom). I'd say it'd be better to use a newer intake manifold on a renix head than to use the renix intake manifold on a newer head. The renix(2686), 7120, and 0630 exhaust manifolds are bigger than the 00-01s/0331's exhaust ports, so using an 00+ 0331 will work, but as warned before, many of the 00 and 01 0331s crack. Do not use an older head on a block that came with an 0331 unless you plan on using an older/made for an older 4.0 exhaust manifold as well cause the exhaust ports on the 0331 are smaller than the renix, 7120s, and 0630s, thus the 0331 exhaust manifolds will not cover the bigger ports of the renix, 7120s, and 0630s.
