- Yucaipa, CA
On my set up, I raised the LCA attachments so that the bottom of the arms are even with the bottom of the axle tube. Then I lowered the frame attachment of the UCAs to get the better geometry back to emilinate the crazy brake dive I had before re-doing the uppers. The angles of the CAs are real close to what a long arm kit would afford, without the loss of ground clearance. The ride is much better on and off road, and I'm not getting hung up on the arms any more either. I still have plenty of articulation. Once the coils are unseated, the only traction you're getting is from unsprung weight on that dropped out tire, which isn't much anyway.
Dan
Dan
