Custom A/C cooled cooler
Gojeep
Australia
Just put this up on eBay for anyone that might be insterested in it with this description.
This is a custom drink cooler to suit 84-97 XJ Jeep Cherokee's. It is made from 3 mm hand formed aluminium and covered in grey trim. It is then insulated with high density 8 mm foam. Cold air from the air conditioning when in use is passed through the rear console vents and into the bottom of the cooler. It then passes around the drink bottles and vents from four openings to keep air flowing and to pass through to passengers in the rear. It holds 6 standard 750 mls bike drink bottles which are not included. Does not take any foot room from the 2 rear passenges as sits over transmission hump on rubber feet. Take only seconds to install and remove.
It is 9.5"Lx6.5"Wx10"D inside the drink holding area so can also fit 12 cans also.
Other pictures here.
See auction here
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=7971105927&ssPageName=ADME:B:LC:AU:1
