Currie anti-rock with aftermarket bumper..?
Silverstreak01
Hometown, NE PA
i am currently running no swaybars. but am intrested in the anti-rock swaybar . but all (i think) after market bumpers block the holes. anyway or anybody got around this little dilema... ?
:laugh2: :laugh: :laugh:
Keith, give me a call if whenever you get a chance.
Im going with the Tera-flex unit,its got the sweetest disco out there.It will mount just below the bumper brackets used my most.
phpThumb.php
http://www.teraflx.com/scripts/phpThumb.php?src=/productIm
ages/975_extended.jpg&w=175
I'm confused. The Currie bar isn't meant to be diconnected. The Tera bar is meant to be discoed? What's the point, why not just stick with a stock anti-sway bar with disco's if you're going to disconnect it anyhow?
BlueGerbil said:
I´ve thought that this systems are "TJ only".... What modification, if any, are necessary to run them on an XJ???
Currie has universal kits with various length components, but you'll have to do some fab work, you'll have to mount the cross tube that houses the bar. Barnett (IIRC) has developed a currie anti-rock that's a bolt-on, but the arms looked kind of short in the photos.
Without crawling under my Jeep or taking any measurements, I'd try to put the bar more forward of the stock swaybar location to use more length of the arms. Maybe the extra length doesn't mean that much.
Who has some real world experience with the Anti-Rock on an XJ? Hinkley? Sinclair? :dunno:
IF Dan Turner doesn't notice this thread send him a PM as he's running the antirock with an aftermarket sway bar. I know that he had to make something to make it work.
XJZ said:
I'm confused.
Hinkley's been running one for a couple years. With his SBS the Currie universal Antirock is a fairly straight forward deal. I put the SBS on in anticipation of this, but havn't got around to it yet.
Paul
Kieth you do not need an anti-rock system with 4.5 inches of lift in the front, when you get 9 inches of lift with coilovers thats when you might want one...IMHO
Paul
Yeah, I've seen photos where tabs used to hold the cross tube have been welded to the steering brace plate.
I have the SBS but have not installed it. I've got to get this damn thing out of the garage!
You're kidding, right?
