Awesome stuff
Glad someone has taken the time to type and share all the good Renix info......
Also adding my 2 cents on CPS adjustment, closer you can get reading to 1.0 volt AC the better while cranking without sensor rubbing the better, as outside temps drop,engine will crank slower and the output CPS voltage will be lower then when its warm....
And for Renix Jeeps that fail emissions after the slew of sensors and O2 replacements few tips..... running fuel pressure cannot be over spec even by a few pounds, triple check the vac line to pressure regulator, check vac line to MAP also.... if your Jeep wont go into closed loop even when coolant and Intake temp are nice and warm , heater voltage to O2 is good, ground is good, 5 volt reference from PCM is good and everything else has been tried I added a MAP sensor enhancer as they call it...... as time goes on the engine vacuum the PCM see's is low enough at idle to cause the PCM to stay in open loop from normal engine wear.... 16.1 inches of vacuum or less will cause this from what I discovered...... so the map enhancer is a cheap and easy way to get the O2 sensor to stay in closed loop.... I can make the PCM see 18.7 inches of vacuum at idle and it stays in closed loop all running conditions and rpm's...It makes the PCM see more engine vaccum which makes it lean..My recent emissions test went from 897 HC and 9.50 CO to 22 HC and .20 CO after I added the enhancer..... Map enhancer is last resort after you have checked all sensors and grounds....... 99% of the time a new O2 sensor will fix the open loop syndrome..... I have a DRB for the Renix and have worked at the dealer for many years in the Renix hey day on Monaco's, Premier's, Alliances and Jeeps........Silicone in the fuel will destroy the O2 sensor which I thought might be my problem, also I was pondering my exhaust temp was dropping below 850 degrees at the O2 sensor.... I tried 3 new o2 sensors I had stashed away and they all acted the same way.... fire it up, warm it up, all good for about 5 minutes, watch the o2 sensor go into closed loop on the DRB, coolant temp 210, IAT/ACT 165, sync working everything working like it should, even had a test light on the heater feed to o2 sensor and watched it..... increase RPM and let idle and o2 goes to .2 volts...sits their for a bit....then bang...open loop 4.97 volts........I pulled my hair out for days cleaning connections and stuff....All I know the MAP might be ioff calibration just a bit, Baro side reads right, just hate tossing 50 bucks for a map and it wasn't the problem.... Map enhancer cost me 14 bucks and saved me allot of money in TUMS
So with people without a DRB you can check to see if your o2 sensor is working with an Analog voltmeter that ranges 0 to 5 volts DC, tap one end into 5 volt reference to PCM at the O2 and the other to a good ground...... needle will move from almost zero to around 4.7 volts, back and fourth...you know its working..... use same method to set your map enhancer.... turn map enhancer clockwise in small steps and watch analog meter hooked to O2 sensor, when you can get the needle to move it's range at all rpm's and revving it up and letting idle then you have enhancer adjusted right...... I cannot tell you actual map voltage as I never hooked a volt meter to it while running and playing around with the enhancer...all set watching info on the DRB........
Okay, done blabbing
..... Just wanted to share my emissions adventure on my 1990 Jeep thats been giving me hell since I moved into town and had to do emissions last 2 years...........
Also the map enhancer will increase gas mileage as you are making the PCM use a different set of fuel and ignition mapping based on MAP sensor reading
...just dont go to lean, you can actually turn the enhancer up to much and the engine will run hot and stall.......
I only made the single mode enhancer, but i am going to make the dual mode enhancer so can flip switch from city to highway settings......
http://www.fuelsaver-mpg.com/simple-map-maf-enhancer
And again, thanks Cruiser for all the awesome info you took the time to share
:clap:
