andyr354
- North Central KS
I was working on some stuff and had an interesting idea for the upper bracing links on a LA setup.
Take two short travel hydraulic cylinders and put them into the place of the upper links. Put to lines on them, running from the front of one to the back of the other and vice versa. Fill them with fluid and get all the air bled out, maybe by putting a T in each hose and hooking it to a temporary resivour.
Once the system is closed one cylinder has to get shorter for the other to get longer. When stufifing one whee the fluid could travel through the system allowing the system to flex better.
While in level road travel though they would not be able to change length.
I dunno, maybe I am just to bored
