CPS replacement, please help...
Casey Not anything I am aware of linking the loose tailpipe with the rough ideling. Try what was suggested, disconnect the negative battery terminal and go consume a couple of beers (your preferance as to brand) then re-attach the battery ground solidly and restart the Jeep. Give it a minute or two to have the ECM re-program itself then all should smooth out. BTW ECM=engine control module or computer for the engine management.
Ok, this is the update...
It's still running like s*it....
It seems like it isn't firing right. It is puttering, and sounds like the exhaust is spitting out air. I have no idea what this could be. It also seems like something underneath is loose. any ideas?
1984 cherokee 2.5
does the 84 2.5 4cyl have the cps? I'm having the same trouble. i replaced the cap and rotor (just bc it needed it anyway). it has good plugs as well.
