- Port Orchard, WA
11:11
11:13
11:13
GEO Tracker through the Backdoor Notch working good and moving on his 35 inch tires...winching the waterfall
11:16
Still winching for the TRACKER on the bottom waterfall of Backdoor. Co-driver out running the winch line tight...crowds cheering
11:16
11:16
Ponce is OUT...broke the front end apart after being stuck in the Backdoor Notch
11:19
11:21
11:21
11:22
Course is clean, and it's time for Doc!
11:22
11:25
Tracker was bumping over the top of the sand hill and towards the desert section...Team 2 is reporting from Backdoor so the finish line crew will have to let you know when they pass the finish line ... if they do...
11:26
Times will be posted after the last racer on course, estimated by 1:00 pm Pacific Standard Time...
11:26
Sounds like #55 has a broken driveshaft at the 1st waterfall on backdoor
11:27
11:28
#55 has a broken driveshaft and has DNFd
11:30
Going to be delayed at the Backdoor as #55 needs to be extracted from the steep rock section of the race course...no race action while race course is closed.
Weather temps are 60 degrees with a mild 40 mph gust and blowing sand
11:34
11:34
http://www.coveritlive.com/index2.p...altcast_code=80b17e0669&width=800&height=550#
11:35
This is the #55 who is still stuck on course...pushed to the side for the final racer. #55 broke a driveshaft!
11:36
11:37
Li ve from Pirate4x4/DIRTnewz.com ==== the latest from the race course!
11:38
The Go Fast sponsored final race car came through the Backdoor Notch and caught fire momentarily, but after popping through the Notch..the engine fire went out and he's continuing towards the first waterfall.
KOH Officials have multiple fire extinguishers on race course following this Go Fast sponsored rig...
11:40
The Go Fast sponsored rock racer is done! The motor won't start after he rolled onto his side...the fans are clearing the race course from both sides of the canyon...as it appears the Last Chance Qualifier is over.
11:40
Full Results within the hour as provided by KOH Officials
11:13
11:13
11:16
11:16
11:16
11:19
11:21
11:21
11:22
11:22
11:25
11:26
11:26
11:27
11:28
11:30
11:34
11:34
11:35
11:36
11:37
11:38
11:40
11:40
