Converting transmission cooler to flexible lines
tumble
Tacoma, WA
I need to relocate one of my transmission lines to make some room, and I'm considering my options. I could use a conversion fitting for the factory hard line to -6 AN and cut my hard lines and splice in a section of flexible tubing and leave the factory ends intact. I could probably even just cut and flare the factory tubing and just clamp in some rubber hose.
But I'm considering converting everything from the transmission forward to two new flexible lines from the transmission outlet all the way to the factory cooler. It looks like the transmission side requires 14mm-1.5 to -6 AN adapters and o-rings. I haven't found any part numbers or sizes to convert back from 3/8-inch hose to the factory transmission cooler ports.
Does anybody have a write-up or recommendation?
Here are the trans adapter fittings and Orings
picture.php
picture.php
picture.php
picture.php
I built mine using mostly summit racing brand fittings and their ptfe -6an hose
Not all xj radiators are the same. What year is yours and what type/size of fittings does it have?
I've a 1997 XJ sport. I'm going to pull the hard lines off this week and I'll double check the radiator side fittings. I got the last of my Boostwerks comp mount fitting done this weekend and the trans lines are the last thing to get done before it's all buttoned up.
