Converting stud-style to eye-style
Fergie
Flagstaff, AZ
I see that companies make a conversion to do this, and it seems like a good idea. However, I dont want to buy new shocks because mine are almost brand new. So, has anyone converted the actual stud mount on the shock into an eye mount, like the lower mount on the rear shocks? Is this even possible(I know it is 'possible' but I mean feasible)? Hope that makes sense, if not I will try to clarify.
Fergie
Are you talking about the bar pin on the top of the rear shocks, or the stud on the top of the fronts?
Well you could do this, but you'd have to make pieces for the shock and the upper shock mount. I'd say by the time you're done screwing around with it, ya woulda been better off getting new shocks and eye conversion pieces. I'm not saying don't do it, I'm just saying take into account the amount of time and fab work you're gonna have to do and weigh it against selling your shocks and buying the required parts.
Sean
Hmmm...
I've never seen a kit to convert this type to an eye ... don't even see how it could be done, short of cutting an eye off an old shock and welding it onto a new one.
What's the advantage? I don't see any point to doing it.
Ahhh good MODIFIED TECH stuff
I know exactly why...to 'lengthen' the droop stroke. I have 'long' Rancho 9009s, that would be perfect if I had OEM axle BP mounts...(yuk) but on my new setup, the lower bar-pin mounts got pruned off the axle and the shock mounts to the outside of the LCAs. The shocks have to travel in an f-r arc rather than straight up/down, on mine it is way beyond what the OEM stud-top style can handle. The bushings max out and this can't do the bushings or inner fender metal any favors...an eye-top setup is required. Plus with my newfound droop, these shocks lack about 3-4" of effective length.
I have a set of 'long' double-eye shocks, so all I need is the upper mounts, but I suppose someone 'handy' could whip something up with some threaded rod/'u' channel for the top mounts, and some pieces of tube with weld-bungs that thread onto the studs on the shock/plis another piece of tube for the 'eye' with bushing to convert the shocks. I love my 9009s but I am not married to them enough to spend all that time/$$ converting them to my needs.
Like always...lots of pieces to the puzzle to connect when ya mod beyond OEM style setups. Have fun and good luck.
Fergie said:
I am referring to the front-upper shock mount.
A bolt, a nut, a couple sway bushings, and some quality time with a welder.
VERY easy. But you'll have to do some simple measurements to make sure you use the right length shock.
LOL Thanks Eagle...
Nope, no convertin for me...too much like extra work, plus I already have new shox that should be the right length.
From the link Eagle posted -
This is their adapter bracket $25. When I first saw this on a jeep, it looked very similar to the top part of the RE swaybar discos. Has anyone used their disco parts the way this adapter bracket is used? Or is it even possible?
I was looking at my RE discos and had the same thought. :idea:
the shock eyes fit in them correctly. The bolts are a little larger nothing a drill won't fix.
Barger
:roll:
Here is another idea
I have Bilstein 5100 shocks which have eyes on both ends. But due to compressed lengths, I couldn't afford to have the standard eye/stud conversion because they took up too much room in the vertical direction. So I made this little guy one afternoon. I welded two 1/2" nuts on the 7/8" bolt. It works great!
Re: Here is another idea
... and that's EXACTLY what I was talking about, and where I got the idea.
Wasn't sure if the bushings were required. After posting earlier and thinking, it seems they wouldn't be.
Re: Re: Here is another idea
You don't need bushings around the 7/8" bolt as long as you have a bushing in the shock eye. but I am pretty sure that is what you meant.
I did the chop and weld stuff - I used a 3/8" SAE bolt welded to the end of the rod - I then threaded a 3/8" female rod end onto the bolt (aka modified thread pitch stud ;) ) I then built a bracket for the rod end to go into...
Been working fine for the last 4 years...
Matt
Re: Re: Re: Here is another idea
Are you sure that is a 7/8" bolt??? The standard shock eye uses a 5/8" bore bushing - shouldered allen head bolts ~3" long and a USS 1/2" threaded shank works great...
A standard 5/8" bolt works well also...
Matt
Re: Re: Re: Re: Here is another idea
Matt
I think you may be confused. The 7/8" bolt goes vertical into the fender mount hole. A 1/2" bolt goes through the bushing of the shock and into the two 1/2" nuts welded to the 7/8" bolt. This puts your shock a little closer to the tire but it is a negligible amount.
Re: Re: Re: Re: Re: Here is another idea
I gotcha - I used a 5/8" bolt there too and just cranked it down - hasn't moved in 4 years - are you using the metal sleaves inside the shock bushings or just the poly bushings alone - I just run the poly with a bolt in it - the sleave would account for the smaller bolt size ;)
To make sure I understand how yours is set up - the 7/8" bolt goes into the fender - the 1/2" nuts welded to the head of that bolt receive the bolt that goes through the main eye of the shock (you are just running this bolt in single shear, correct?) You just ues shocks with an eye on the top (mine were like that originally - RS9012's with the top eye cut off)
The placement toward the tire is a good thing as under full flex my old OEM mounted shocks would have the rod contact the frame just barely - I have since move the mounts out with my extra width front end...
Matt
