zluster
- Colorado Baby!
Here's the deal, I want to retain my stock Jeep wheels. It's a deal breaker for me. The JK axle is wide, spacers will make it even wider, on that note I soldier on ahead........
The XJ/MJ/TJ/WJ/ZJ knuckles WILL NOT bolt onto the JK inner C's. I hadn't heard anything probative on that, and now I know for sure. In addition to the knuckle being a little too "small" the taper on the bottom balljoint appears to be different.
Now for the hub, as I suspected the hub will interchange between the two, so at the very lease the XJ hub will bolt into the JK knuckle for whatever good that will do me.
Note the hub isn't fully installed or clocked correctly, I just wanted to show that it will in fact install into the XJ D30 knuckle.
And now the shaft, thicker and with more splines, so the JK shafts wont mate to the XJ D30 hubs.
So right now my two options are:
Find a U joint to mate between the XJ stub and the JK shaft(weaker).
Redrill the JK hub in some manner to make it 5x4.5.
Lug adapters really aren't an option for me unless I can find some that are only about .75 inches thick. The JK 44 is about 5 inches wider than a XJ D30, and by the time you throw on lug adapters(spidertrax for example would add about 3" to the overall width) thats alot of extra tire sticking out.
So time to consider some more options......................anyone know if any other hubs might bolt in that have the correct spline count? This unit bearing hub seems to be fairly common, see it on fords and such, I just wonder if any of them have the correct spline count and bolt pattern.
