Confused about bump steer
Checkout how team naxja mounted the trackbar on the axle end.
you can also move the frame side forward a bit
Should take care of the length problem using a little of both approaches
http://www.naxja.org/forum/showthread.php?t=1075100&page=8
The only problem is that it won't work with stock brackets on the axle. The coil buckets are pushed to far forward. But if you are adding your own brackets, I think its awesome.
