Vanimal
- escondido, ca
i wouldnt ditch the pitman arm, the angles look like they'll be pretty close with only ditching the lower track bar bracket.
On the kits I do, the track bar is moved to the steering stab location on the diff and the stab moved. That location shares the same pivot area as the steering. Get them both in the same area and the bumpsteer will mostly go away. Your current track bar on the diff is in the stock location while the steering pivot is well above it.
I've done many of these kits and there is zero bumpsteer.
Nothing you said makes sense, so post up some pictures..
Pretty simple. The track bar diff location is mounted to the existing steering stab mount and the stab mount is relocated. With stock y-type steering and 4 1/2" lift or better, this is a prime location and eliminates most if not all bumpsteer. If people can't see this, it's not my problem. Look at where the drivers tie rod and drag link meet. Someone asked, I offered my experienced opinion and I get crap for it. Must be the XJ version of Pirate.
Wtf does the tie-rod have to do with it? :doh:
I recon your replying to my post. A tie rod is a part of the steering system it usually connects two TREs.. that's a tie rod end. the statement is you will see alot of people draw a line showing the angel of their tierod and track bar. the thinking is if they are at the same angle all is good. this information is not correct. due to the fact that the relationship between the two parts have more involved than just the angle . after someone raises the suspension above stock, the "stock" operating relationship between the parts are no longer valid. this is due to there difference in length and geometry . the diagram link will help you understand. im sure you have some smart ass reply ,,but i take it all as free entertainment.
rockclimber
It’s a tie rod, drag link same thing different words. in the case of this discussion they do the same thing they push and pull, and connect ..its like “tater” “potato” same thing no need to try to get anal.
call moog tell them they got it wrong why your at it
Bumping an old thread with a somewhat specific question. I have a drop pitman arm and drop track bar mount so they are close in position. I am going to build new heim steering and I have a dilemma.
Do I run the drag link all the way to the pass spindle making it 3" longer than the track bar I have or just build a 34" long drag link to match the track bar and make it an inverted T?
One gives me a dead spot and the other bump steer. Anyone know how bad the bump steer might be with a 3"
Difference?
I have 5.5" rubicon express lift but the drop arm and track bar mount make the drag link angle tolerable.
