Location: Salem, Oregon - can ship via fedex for about $40
COMPLETE TPI setup ! came off a 1986 Firebird with chevy small block 305. This is a very very complete setup, it comes with just about every thing you will need to swap to TPI. Everything looks in good shape too.
86 TPI intake which will fit 86 and older small block chevy heads without any modifications. 87 and newer heads will not fit this intake w/o mods.
86 TPI setup is the year you want, MAF sensor is better for high performance applications. This computer is a 86 model which is a faster one than the older 85 and works good.
Intake is complete, injectors, runners, throttle body, fuel pressure regulator plugs and wires, thermostat housing, distributor housing cover,
Comes with all the Air filter box, tubes and etc, comes with a GM MAF sensor.
This setup has the speed sensor off a 700R4 automatic transmissio, includes speedo gears and etc. Also have all the other sensors needed. Knock sensors, temp sensors and etc.
All nuts and bolts are here.. including all nuts and bolts on the intake assembly.
Comes with the electric fan which you will probably need, since it's a MAF system.
Fuel pump and pick up assembly included, fits alot of GM gas tanks, line end fittings are there so you can match them or add them to your fuel lines.
Has the HEI coil top mounted distributor
All the cruise control parts and hoses so you can hook that up if you wanted to.
Computer with brackets needed to mount.
All the wiring is there including the ALDL connector. The wiring has been very carefully taken apart and not cutted up in any way, even the turn single light bulbs are in the wiring harness, and battery positive cable hook up.
Go here for high quality pics of this setup:
http://bonehead.transamrit.net/tpi/
Email me with any questions at [email protected]
