Complete D35 and Dana 30 gears - 4.11 ratio
RWKHausSupply
upgraded a perfectly fine 1994 YJ with the D35 rear and D30HP front, with a new rear axle w 4.56 gears and regeared the front.
complete D35 rear w/4.11 gear ratio, with E-brake cables, Hyd brake line all the way to the frame connection, yoke cover and good condition brakes. Ready to Run/install.
Also D30 high pinion 4.11 gear set in great condition with brand new carrier and new uninstalled carrier bearings, pinion has original bearings included.
If only interested in the gear the front and rear should fit your XJ If its a D35 rear and High pinion front, or I can swap them for you.
200$ and take it all. Located in Yorba Linda.
714-875-2414
