YELLAHEEP
- Littleton, Colorado
Re: The Colorado BS thread
This ^^^
The sensor Kastein may be seeing on a Renix is the knock sensor. Coolant temp sensors are found at the back of the cylinder head on the intake manifold side. The other sensor for temps would be the one found in the t-stat housing which is for the fan circuit.
thought it was the plug/bolt at back under map on the block?
This ^^^
