- Colorado Springs, CO
Re: The Colorado BS thread
http://www.salina.com/news/long-mca...cle_46af5856-91a9-5a58-9ae2-20750444ab2f.html
Did they somehow have the new helmet design in 1975?
EDIT... NM. Just saw it was restored when the badges were added.
It would take me approximately three seconds to die if I tried one of those bikes.
ilovejeeps51 said:Install your lift with no shim, or if you want to guess start with a 3deg shim.
MEASURE your pinion angle, and more importantly your operating angle (difference between the driveshaft angle and the pinion angle).
For ujoint life you should keep your working angle at about 2-3deg. in other words your pinion should be 2deg - 3deg below your driveshaft.
NOTE - this is assuming you do not have a double cardon joint at the t-case (stock is single cardon). If you install a slip yoke eliminator kit with a double cardon joint the pinion angle should be right in line with the driveshaft...
I just watched a few clips on youtube: Freakin' sick movie. :laugh:Awesome movie.
Good to here you are still kicking. Going to make it to the M&G this weekend?
