Front end-
Truss installed- DONE
tubes welded-DONE
c's Braced and welded
Lower control arm skids
Cut and extend lower control arms for more stretch-DONE ALONG WITH UPPERS
maybe have to move track bar mount (cut and weld forward a bit) -DONT NEED TO DO. BUT I MOVED THE COIL BUCKETS AN INCH BACKWARDS AND BOXED THEM ALL IN
Front frame stiffners
DROPED 14MM DEEP SOCKET INTO UNIBODY:soapbox:
Middle-
fix the damn transfercase linkage by welding in little spacer.
Door guards (skinning the lower half like my quarter pannels)
Rear-
Finish making rear truss
Install it
weld tubes
Inside swing out rear tire carrier for spare 37 maybe...
All around goal:
get jeep ready to wheel with 37s. Stretch Bumpstop, and ontop of that I might move my shock mounts to retain same amount of travel, but in droop instead of uptravle.
