Coleman Quickbed SUV Air Mattress
Well it's 71" x 41" so you can measure to see if it will fit. If so, probably a good option. Also, I could be wrong but it appears the only difference between this one and a regular twin-sized coleman mattress is that this is 71" long instead of 74" but that seperate peice could be the difference. This is making me wonder....if I can find a measuring tape at work, I'm going to go measure real quick.
Survey Says - No dice. Only ~ 60 inches.
most inflatible air matresses should work. i could fit one perfectly inside and simply did not fill it up all the way (its air a plastic, it will mold to fit if needed) and it was pretty comfortable, any twin sized should work if you take out the bottom piece of the rear seat and move the seats forward.
