- Henderson, NV
Alright, I've started ordering parts for my dana 30 build, and I've probably spent more time reading and researching than I should, but when you have more time than money, what else are you to do? :laugh:
My Dana 30 build so far I've decided this:
Artecs truss with Artec's UCA mount And stock bushings
Gussets on the inner Cs
Rotate inner Cs for 5* caster at 10* pinion angle
WJ steering/ brakes
Now, I've seen more people use the JKS track bar bracket than not, so that's the direction I'm headed, but if I'm rotating the inner Cs, then the coil buckets are going to be off. I have thought about buying new coil buckets to remedy this. Ideally i know that the track bar should be the same length and angle of the drag link, but as others have pointed out unless you move the coil back and mount the track bar on the Inner C, you won't be able to do that.
So if I'm buying coil buckets anyway, should I get ones Like TNTs where they center the coil over the axle? Or am I just wasting time and money on something that won't affect the jeep that much?
And if I do relocate the coil, what else has to be changed to do this?
WJ steering/ brakes
