burntkat
NAXJA Member #1145
- Charleston, SC
I am not running an AT thermostat. Both coolers are fed at the bottom port. They marginally keep up while wheeling, runs about 180 in 4wd while climbing hills (which isn't bad considering how cheap both coolers were). Once I upgrade it should be perfect.
And earlier...
Current cooler setup. Cheap Hayden trans cooler (which is getting upgraded to a Tru-Cool cooler). A small p/s cooler, the a/c condenser and the 4.5" thick radiator. Down below is the secondary trans cooler (actually the lower trans cooler is full time while the upper one in front of the radiator comes in at 180 degrees via thermostat).
I are confuzled......
Are you, or aren't you?
Fair disclosure, I haven't had my coffee yet, so may well be just retarded via caffeine deficit.
