Clunking noise on right side.
BenXJCA
I drive over speed bumps to get to where I live. I drive over them with my left tires (the right ones in the gutter area). Something in the front suspension left side clunks when I go over the speed bumps, as well as other sharp jouncing obstacles. Its really annoying and it makes me feel as if the front is going to fall apart. It was there even with fixed control arms.
Any ideas? anyone?
TIA
You would probably get a better response in the OEM Tech. It sounds like either your upper control arm bushings, or your rubber exhaust mount at the crosmember. Check the upper control arm bushings by backing up and sharply applying the brakes. If you get the clunking noise it’s the bushings.
