So after the previous post, I went and hung out w/ a friend for a little over an hour. I restarted the Jeep and it was reading 55* and was in cl already, so that further confirms my sketchy feeling about the results from the previous post. I'll report back with the results from tomorrow's warm-up. . .
Edit: I replaced my gauge temp sender a while ago and noted that the temps stayed a little to the right of the 210* mark(whereas it was a equally to the left on the old one--no biggie, just noted/referenced). This ~215*F on the dash is 86*C(187*F), according to the lm-2 that is scanning the pcm. The cts has tolerances as well, so can actually be +/- that, but is definitely more accurate than the sender/dash gauge combo, .
