Cleaning out the garage
J-9
I'm tired of this stuff lying around. I can provide more info or pics if needed.
XJ rear Dana 44, 3.54s, open diff. I pulled this from a junkyard in NY so it’s a bit rusty, been sitting in the garage since - $200
D44 diff guard, powder coated black, with hardware, never used - $50
Stock 8.25 diff cover, pulled from junkyard - FREE
C-ROK steering box reinforcement for XJ, outside frame plate only, no hardware. I ran this for about a year - $20
Harmonic Balancer (Napa Balkamp part no 600-5229), about 3 years old, used less than a year on my ’92 XJ - $15
Rubicon Express 3.5" Coil springs - Used for a couple years and sat around for a couple, but still in good condition - $100.
T&T Customs XJ Uni-Body Stiffeners, never used - $100
Kevins Offroad XJ track bar with bracket - Needs new bushings w/ sleeves (missing one) and could use a cleaning, no hardware - $100
Procomp 92651 21094 Explorer C021Y2 shock, stud/eye configuration, about 17" compressed, 27" extended, no bushings/hardware, never used. This is a single shock, not even sure if it’s meant for an XJ - $10
2x4 Tomken Rocker Skids for XJ – I wheeled on these for 10 years, mounts were cut to fit RE long arm kit, no hardware. These are quite rusty and will need a good cleaning - $25
Stock 96.5+ NP231 main shaft and tail cone - Been sitting around for quite some time after an SYE install. I think it'll work for anyone interested in installing the RE1807 Hack and Tap kit. Needs new output seal. Really would just like to see it gone, so make an offer.
Set of 4 TrXus MT 33x12.5R15 tires - Well used, but three are still in OK shape (not touching the wear bars yet, would make good spares), forth is worn funny and touching wear bars in center of tread - $25ea/$75all
Set of 4 BFG KM 33x12.5R15 tires - siped, 3 with reasonable tread, 1 down to wear bar - $25ea/$75all
Set of 4 TrXus MT 31x10.5R15 tires on stock alloys Jeep rims - 3 tires with reasonable tread, 1 down to wear bar, rims beat from wheeling, balanced with airsoft. Tires are fairly old but no obvious dry rot – FREE
31s are gone.
D44 diff guard:
Sliders:
TruXus 31s, KM 33s, rock sliders, coil springs and frame stiffeners have sold.
Also for sale:
JKS Drag link for WJ knuckle swap. Includes jam nuts and Moog TRE for pitman arm (ES3474, needs new boot and missing castle nut). Used for only about a year and in great shape. Will include damaged RHD TRE for knuckle end if desired for mockup purposes - $120
Moog ES3475 - WJ TRE. New but missing castle nut and cotter pin - $30
