Cleaning Out The Garage
o2bgpn
Tucson
Ladies and gentlemen, boys and girls step right up and check out my junk. Wait, that didn’t sound right.
I put on a long arm kit so I’m selling stuff I no longer need or want. All of it came off a ’97 with manual transmission, so keep that in mind.
Progressive coil springs from Tomken. Originally 4 inch lift probably now around 3 inch lift. $50
2 inch coil spacers, steel. $10
Upper and lower control arms for Tomken 6 inch lift. Non adjustable but Johnny Joints are rebuildable. $50
I couldn’t get the bolt out of one of the lower controls arms (I didn’t try very hard) so I just cut it off the frame.
All the above will give you around 5 inches of lift in front and I’ll let go as a set for $100
New in package (though they are probably around 8 years old) control arm poly bushings. $20
Tomken transfer case skid plate. Made of 3/16" steel plate. Covers from frame rail to frame rail with cut out for catalytic converter. $40
Top side of skid has stand offs to accommodate a 1 inch transfer case drop
Speaking of transfer case drops; 1 inch transfer case drop kit $5
Transmission skid plate - never installed. Hooks to front of crossmember. $40
I’ve had this skid plate for at least 8 years, kept the instructions with it all this time, and ripped them pulling them out from under the skid plate to take this picture.
Semi-beat up crossmember. $20
Front and rear drive shaft. Front was shortened by about half an inch (because short arm droop cause it to bottom out), rear has a minor dent. All u-joints are good. $40 each
231 tail shaft housing and stock main shaft. Beer$
Reply here, shoot me an email (o2bgpn at cox dot net), or give me a call – 663. 3570
Thanks for looking.
TTT. All prices are negotiable - I just want this stuff gone.
will you ship ?
Sure, I'll ship - on your dime. You've got a PM.
For others in Phoenix I can meet half way, which for me would be around Eloy. If you could get a Phoenix rep to send down we could do this in one parts run.
chvynova-71 said:
i want the arms. how much do you have to have for them. (remember how bad you want them gone, i could have them out of there by the end of friday)
The arms are spoken for.^^ I'll let you know if the deal falls through.
chrslefty said:
I'll take the skid plates.
They work together correct ?
The skid plates attach to the stock crossmember. The transmission one hooks to the top front lip of the crossmember and has a cross brace which goes between the frame rails. I've got all the original hardware but it has never been mounted.
Here is a picture of the transfer case skid plat on the Heep. Remember I've welded some spacers on the skid plate to accommodate a 1 inch drop, but the spacers could be ground off rather easily.
Oh, and I'm available to make the run pretty much any day from noon to around 5 pm (except Saturday). Or I can ship........ on your dime (until I run out of boxes). :)
I'll give u a holler . I'm going to be heading back from yuma on Mon .so if we could meet in eloy then that would be awsome. Unless someone is going sooner ill kick in for some gas money.or if anyone wants me to pick somthing up for them and can waited tell Mon .let me know .
If you're coming from Yuma we could just as easily meet at the east side of the I8/I10 interchange. I'm not too familiar with the area but Google Earth says the first exit on east I10 would be Sunland Gin Rd. There looks to be a Burger King on the north side of the freeway. Want to meet there? Give me a time.
Or if you know a better place....
Sounds good to me .
Would calling on Mon be ok ?
Have to take my kiddo to a Dr apt on Mon morning .and ill be hitting the road after that so I'll have a better idea of when ill be there after its over.
Sounds good to me .
Sure, as long as we're at BK before 5 pm - I have to work that night. I'll PM you with my phone number.
What I have left ...
Coils
Transfer Case Drop
Crossmember
Drive Shafts
Tail Shaft Housing
Main Shaft
