It will slice thru all sorts of word - hard to soft...splitz said:Yeah, I saw that ax at Lowes and almost picked it up. How does it do with splitting?
Benz0 said:Fiskars...hands down
splitz said:Well I just picked up the axe. It is a really good axe, but y'all were right, an ax is not a good splitter.
I still need some practice with it, but is chops through trees with ease. Thanks for the tip!
Stumpalump said:http://store.baileys-online.com/cgi-bin/baileys/scan/arg=%22/fi=products/st=db/tf=sortorder%2cdescription/co=yes/sf=category/se=140/op=eq/ml=10.html
I have never been that happy with my Eastwing hatchet. I like the cheap china one because I don't feel bad beating it up on rocks and roots and then just taking the grinder to it. Since you have that nice new one you may want to pick up a el cheap to use on stuff close to the ground. Google arborist or lumber jack and check out the competition stuff for fun. I wound up with a bad ass husquavarna 346XP chainsaw but its so fast your done before the saw is warmed up.
Those little craftsman/polan saws are great. Especially the small ones. You can grind off the emmissions stops on the carbs and open up the exhoust and they run great. The husky professional line is a whole different animal. It just falls thru the wood and it takes the fun out if working the saw but you need two saws in case one binds in a tree so the poland is the best for that and if you need to climb a tree with a lighter saw. I have a nice high end hand pruning saw that will rip thru a pretty big tree and is good to keep in the jeep in case a trail is blocked by dead fall.XJ Dreamin' said:For the chainsaw option I've got a cheap Craftsman (Poulan clone). I do better with my cheapa$$ saw than most guys I know with higher class equipment because I keep the chain in shape and let the saw do the work. Of course, if you keep your Husquavarna in good shape you'll cut circles around my poor little Craftsman, but for what I need the price was right.
Stumpalump said:Those little craftsman/polan saws are great. Especially the small ones. You can grind off the emmissions stops on the carbs and open up the exhoust and they run great. The husky professional line is a whole different animal. It just falls thru the wood and it takes the fun out if working the saw but you need two saws in case one binds in a tree so the poland is the best for that and if you need to climb a tree with a lighter saw. I have a nice high end hand pruning saw that will rip thru a pretty big tree and is good to keep in the jeep in case a trail is blocked by dead fall.
XJ Dreamin' said:I've got the cutest little McCulloch. A 10" bar, no chain brake, you have to pump the oiler with your thumb continuously while you're cutting - it almost fits in the palm of your hand. I'm not running it right now because I need to find someone who can fix the oiler. I showed it to the tree trimming guy when he was out here after Rita and it gave him a good laugh. If I can remember, I'll get a picture of it next to the Craftsman, for scale.
