NorCalChris
- Central Coast, Ca
What brand are you using. Whats the good and bad about them...
I honestly was going to purchase one from HF, to see how it lasts. Theres a fab shop next to mine and he use's a Makita chop saw and a dewalt. Figured I might go with one of those when the HF fails.
To avoid spending too much this month on tools. =Dthis makes no sense at all. :twak:
if you plan on buying a good one when the HF one fails, why not just buy the good one first instead of throwing your money away on some HF piece of crap???
I think the biggest things are the base and the blades you use. Make sure you look at the base on them all before you purchase anything. I've got Milwaukee's 6180-20 (careful, they also have a less desirable version with a slightly different model number). I love the saw, plenty of power. As for blades, I know it hurts to spend $9-11 on a blade, but the $3-4 ones just won't cut anywhere near as well. Make sure you have a spare or two on hand.
x2 on everything RCMan said.
x2 on avoiding hf crap.
I have a milwaukee, and never use it anymore, too messy, blade deflects under load, and did i mention its messy?
I gave $75 for mine, I have seen similiar deals, depending on what you need to cut, I have seen kits to convert an angle grinder to use as a cut off saw
also as mentioned the blade does deflect! be prepared to grind to fit, or fill, they are not the most accurate way to cut by no means, but for some jobs, I do prefer, like making hand rails around a porch. I also have a 7" circular saw with an abrasive wheel for small jobs, or light "filing trimming" as well as my grinders, bought the saw for $20 at flea market.
I also have a Milwaukee 6180-20 Chop Saw and use Norton blades with it. It works just fine... but I prefer to use my Milwaukee portaband if I can help it. It makes virtually zero mess when compared to the chop saw, its faster and much quieter.
Look into them too if you can... they can be had fairly cheap used. If used properly, a couple blades will last you quite a long time!
