Hey Fam :woohoo:
I'm reevaluating my front suspension, as in correcting sagging springs, adjustable arms and adding drop brackets. Not interested in long arms for my needs, thanks though.
Originally I installed Rusty's 3" coils and a RE 3/4" spacer, which netted me exactly 4" on the front with stock arms. That was almost 3 years ago, and now, even with the RE spacer, I've dropped to 3" in the front. The 150lb rate is a soft ride, but did not bear the burden. Also IRO double shear track bar, Bilstein 5100s, SYE and shaft, and rear is OME leafs and Rusty's 3/4" shackles, still at a hair over 4" strong.
Plan is to install my PAC 4" coils, add RC drop brackets, get my pinion correct with a set of adjustable arms, and then have my Cs rotated for correct caster. Local shop owes me, so the Cs rotation is free!
I'm between IRO and Core4x4 for arms. If you have/had a set of these, what was your experience? What do you recommend, one over the other, or a different brand?
