i recently had to leave my 86 monte at a garage for insp.they were gonna play with the carb for emmisions.they got it thru and my wife has been driving it since.this was about 3 weeks ago.i took it out the other day and punched it once to merge on the hyway.i saw lotsa blue smoke behind me and now im really confused.it only seems to smoke when i get on it.this is a 350 crate engine .the 350 deluxe vortec with a build date of 2001.i bought it brand new and never really beat on it and kept well up on all of the maintainence.i pulled the plugs from the smoking side and found all of the plugs to be in great cond except for the one forward of the last.(i believe this to be #6)this one was just about completely oil fouled.i changed the plugs just 2 mos ago and all was fine.the ones i took out were all normal.i cleaned this plug up and swapped it with another.i bought a new pcv(this plug is directly below it)and went for a spin.it still smoked from the pass side on heavy acceleration.then i pulled the pcv out completely and tried it again and it still smoked.i did a compression test on the pass side and they were all 165 but when i pulled the #6 plug it was close to being oil fouled again after just 2 days.the car runs fine off idle but is idling terrible since this started.at idle im getting between 13 and 15 on a vac gage at around 750 rpm.everyone is telling me that is a bad valve seal and i was agreeing untill salle chevy told me that it is probobly the intake gasket.i special ordered a improved design fel pro one today for 25 bux.has anyone ever had a problem like this?
any help is greatly appreciated.
