Cherokee dana 44 - $3464
cal
Hammertown, USA
Solid axle third member
Tubed in 3/8 DOM, stock width
Trussed and gusseted
TJ inner knuckles
WJ outer knuckles
Yukon Grizzly locker
Yukon 4.88 gears
Chromo 'super 30' inner axles
CTM joints with fresh rebuild
Synergy JK balljoints
Warn 5x5.5 hub kit on WJ knuckles
Bobby Long spindle bearing delete (delrin bushings)
Stage 8 spindle nuts
Custom Black Magic brake kit
Yukon chromo 30 spline drive slugs
1.5x.250 DOM steering over the knuckle with 7/8 rod ends
1 ton TRE at pitman arm
Extra long trackbar to the inner knuckle
Solid Axles diff cover
PSC hydro assist ram
Deaver 5.5 progressive jeepspeed coils
Prothane coil inserts with hard bumps inside
Comes with two full sets of shafts (with ctms)
Two spare spindles
Two spare hubs
Two spare rotors
Two spare yokes
Four full sets of seals and bearings
Two sets of warn locking hubs
Spare steering joints
Spare reamed pitman arm
NOT BENT! :)
Setup to bolt in to an XJ. Add your own:
shocks (setup for 12" Bilstein 9100 2.65)
trackbar bracket/brace (setup for RE bracket with the hole drilled out)
currie antirock (with bent arms)
Interested in a few things if you want to part it out.
I'm interested in this for a 70s land cruiser project I'm working on, is it cash only? Out would you be willing to do some sort of trade?
*blink*
Either you totally failed, or you just totally won the game.
I noticed on the Facebook page you had a 30 gallon fuel cell listed. Is that the Genright fuel cell? Let me know, I'm really interested in it. Thanks, Mike
I’m just realizing how this works. I can mount this axle to the back of my Jeep so it has rear steer correct?
If you're parting it out, I'll take the hard bumps inside the Prothanes.
David Bricker / SYR
Since apparently a couple of people didnt catch on....
"april fools".
On a more serious note, you still have that other sucker actuator?
