Cherokee budget turbo build thread
Would you want to sell me a turbo kit too assuming yours turns out well?? I am not to far from you.
Good luck!!
Um, maybe. I can jig up my piping I guess. My father lives in Schenectady. Let me see how this all works out. lol
That's great!! I hope yours turns out well.
Ravi
Im in a holding pattern. My wideband is a DOA and they are sending me out another one. I fired the Jeep up today open header with the big injectors and it ran well. Going to do the oil lines tonight and tomorrow and then the final install.
It was a PLX SM-AFR/DM5 combo. I used to only use Innovate as well. The last turbo car I owned I figured on trying the PLX. I like the display and packaging. It worked great.
ITS ALIVE!!! I took it around the block. Runs well for no tuning done. My new wideband was already shipped out to replace the defect. It overboosted the first time I briefly pulled it. I adjusted the wastegate and its good now. Not boosting it again till I can get the wideband in and I dont have to time today to borrow the one I was going to use. Here it is.
Build totals are shipped to my door.
Turbo .63/.60 T3/T04E Ebay $185 New
MSD BTM Shop I work for. $60 New
Apexi VAFC D-series.org classifieds $85 Used
PLX SM-AFR/DM5 wideband www.needfulltoyz.com $242 New
AEM air filter Ebay $24 New
Gauge pod Ebay $14 New
Boost gauge Ebay $14 New
Blow off valve Ebay $25 New
Piping and V-band http://store.racing-solutions.org/ $112.50 New
Silicone couplers www.siliconeintakes.com $45 New
36# injectors www.southbayfuelinjectors.com $141 Reman
Oil lines and fittings local $55 New
Aluminum charge pipe Left over I had Free New
T3 flange Weirtech $10 New
O2 bungs I use jam nuts $5 New
DEI header wrap Shop I work for. Free New
Heat shield Homedepot sheet aluminum $10 New
Misc crap like oil pan gasket, oil, clamps, zip ties, crimp connector, solder, Argon, filler rod. Figure about $ 75
Total=$1027
That says you don't have a wideband installed.
CS, long time since I've seen you around HMT. Good to see you still have the XJ.
Had plan to turbo mine, but going with an IHI Supercharger off the wife's old Mazda Millenia.
we gunna c this jeep do some 0 to 60 and mud bog and street burnouts right? That is some good work. I hope u know what ur doing with the tuning because it is not a low compression motor so depending on how much cfms that turbo puts out and ur fuel flow. I hope the best though.
