Checking a Manual Renix TPS
ptf18
Texas
Checked the resistance of the wiring of the terminal "B" on my Renix TPS (manual).
I got 1.5 ohms.
Is that high/low?
I checked it from the connector to the firewall ground then to the battery post ground, then the engine block. All the resistance readings were the same 1.4-1.5 ohms.
You check voltage on the TPS, not resistance. Search for "TPS asjustment and you'll find the specs, Or, someone who knows the answer off the top of their head will hopefully chime in.
