Alopanec
- California
I have a 98 with a 4.0 ax 15 and its white I can drive a month with the air conditioning on and I won't get a cel but if I drive with it off I can hear and if I put my hand on the exhaust I can feel my hand get sucked in indicating a miss and ill get a cel after 2 or 3 starts and I have tested my theory about the a.c. multiple times it holds true every time I have replaced plugs wires cap rotor fuel pump and i.a.c I plan on changing 02 sensors this weekend just because I'm sure they are old and have never been changes and I have a smog coming up I've ran multiple bottles of sea foam in the fuel and a can of the spray for the intake I've also did a compression test and everything was between 80 and 95 I know it's low as factory says 120 I think but its got 200k miles on her plus I don't think it would be a intermittent issue if it was low compression I really think it's a vaccume issue but not sure I've checked vaccume and everything seemed good but one really wierd thing was that one of the vaccume lines was full of water I thought that was strange and if I blow in it I can hear bubbles from somewhere
