has anyone failed the sniffer using a non-ca cat? I understand you can fail the visual if you are silly enough to not scrape the MFG date off on "rocks" but what about experience with the sniffer?
thats what I figured. My understanding of these cheap cats is that they are manufactured to the EPA minimums for the year/vehicle they are replacing so you might have one that is not as effective as the OEM cat was from the factory, but a new one at EPA minimum is still probably as effective or more effective than an OEM cat at 150k miles which mine is and is not even close to failing.
