sherman08
- Belfair WA
Don't look now but it seems you have uh, some custom paint, good detail on the uh, phallic symbols. Now i better understand "hillbilly"
I guess my question is an open system better then a closed system. And or is there just a better way to cool the 242.
never just shut an engine off if it is over heating. let it idle and circulate the coolant. esspecially on a closed system it allows water to stay in one place and be boiled causing mass pressure and probably resulting in blowing a hose or your bottle. at least with the engine running the water is still being circulated throug the motor and rad. you can still ad water with it running if it is low.Uh, this is wrong on so many levels. You're the first person to think closed systems are better. Ever. People replace the plastic bottle because they crack and become useless. I've never heard of fixing overheating by swapping bottles. That just defies logic. Lastly, they run at 210 because that's the thermostat they run.
To be fair, I did do something wrong at NWF08. If a vehicle is running a trail and overheating, common sense tells me the cooling system cant keep up with a running rig. Shut the rig down, top it off, and check for air in the system. Apparently everyone else thought the right thing to do was run it while overheating. I may know nothing.
here's a couple of the xj's and a yj that had his front bumper customized by one of the hillclimbs good thing he had a ski rack
http://i138.photobucket.com/albums/q241/lorax81/mudrun09004.jpg
Earlier you say you have a fairly new 3 core radiator...what is "not new" in your closed loop system that you think is causing it to over heat?but as far as the coolant issue i believe that a new good closed system is supperior. but mine is not new and it was deffinitly over heating. prior to the run it got all new coolant and a bottle of napa kool. All i could do was one hillclimb or 3 laps around the track before i was over heating and had to let it sit idleing too cool.
I can say I've never seen anyone go muddin with tire chains on!
the heater core is the only thing that hasn't been replaced. I don't think that would cause it to over heat. I have a open system rad I can swap in and convert the system over. next question does anyone have a link for a good puller fan for the front of the rad. and will I need to upgrade my alt for running 3 more fans.Earlier you say you have a fairly new 3 core radiator...what is "not new" in your closed loop system that you think is causing it to over heat?
Also, I have to agree with Paul; you're not going to find many fans of the closed loop system anywhere, new bottle or not. I converted my '89s closed system to open and ran 600 miles at WOT and it never got hot at all, just running water and water wetter.
-----Matt-----
3 fans? Why? If everything else is working, you should only need the standard mechanical fan and the aux IF it starts getting warm.the heater core is the only thing that hasn't been replaced. I don't think that would cause it to over heat. I have a open system rad I can swap in and convert the system over. next question does anyone have a link for a good puller fan for the front of the rad. and will I need to upgrade my alt for running 3 more fans.
because the one mechanical fan isn't moving enough air to keep things cool.3 fans? Why? If everything else is working, you should only need the standard mechanical fan and the aux IF it starts getting warm.
Also, all I did to mine was add a T fitting with a radiator cap and pulled out the pressure bottle. Put an overflow bottle there and called it good; like I said, it ran flawlessly for over 600 miles at wide open throttle.
-----Matt-----
Search the topic, you'll find it's a love hate, 50/50 deal. Many reputable posters on this site (5-90 comes to mind) find the closed system a good system when working properly. The problem is many people with closed systems don't take the time to fix the problems 20 year old cars acquire. I think 75% of the 10 cars in my driveway (well, kinda in my driveway) are closed system and not one have over heated (including my new rig, after I rebuilt the coolant system properly).
There's no doubt, the open system for the stock Cherokees is a no brainer easy to maintain system. However, the closed system when equipped properly is more efficient, IMO. With that said, I'd have no complaints running either system at any point in time. I bought a car with a closed system, I replaced everything in that system over time, and now it runs so well I have a hard time wanting to change anything.
Plus as was said earlier, NEVER shut an engine off when it's over heating. Doing that will prevent the water from flowing threw the engine and will just cause more heat to build, instead you should catch it before it gets too hot (if possible) and pull to a level surface, crank the heat on in the car (to allow the hot air to cool down with the fan for that), make sure your fans are all on, and wait. This is all assuming of course you aren't puking fluid everywhere due to failure.
Then again, I'm just an 18 year old kid on his second rig in 1.5 years (4th car in 3 years). What do I know?
~Scott
P.S. I thought most thermostats were 190 in the XJ, because it's set to OPEN at 190 degrees, but the engine is likely going to climb a little past that. Oh and don't be so quick to judge. You've never heard of people replacing the bottle fixing over heating because you obviously haven't listened. The bottle is the main problem, if it leaks, you WILL overheat. Period.
There is nothing wrong with either system.
Both will do there job fine as long as the system is working as designed and all the parts are in good condition.
The MOST common issues I see on either system that give people issues are these.
1. Mechanical fan shroud missing. A fan without a shroud is nearly useless, you need a fan shroud for ALL fans.
2. Electrical fan, this should be available to suplement the mechanical fan and should be working when the engine get's hot, it also should have a fan shroud.
3. Mechanical fan clutch. There is a clutch in the mechanical fan and it can wear out over time, just because the fan is going around doesn't mean that it is working properly. Replace the fan clutch or look up how to "lock up" your current clutch or stiffen it to make sure this isn't your issue.
4. Clean 50/50 water/coolant. Make sure the system is clean and mix is correct. The correct amount of each product is vital to a good system.
5. The platic coolant bottle is crap, they crack, loose pressure ALL of the time, replace it with a decent aluminum one if you are going to stick with the original system. If you are going to switch to the newer system then any overflow bottle should work fine since it won't be under pressure.
Michael
I read through the whole thread and I think the overheating issue (if not a leaky bottle) may be the fact that you aren't running an electric fan. You said was overheating when in low on hill climbs. That's when my 88 use to get hot. I just straight wired the aux fan to the battery and cooled right off. (that was just a trail fix).
If the clutch was stuck it would still spin the fan. Fan clutches slow down the spin of the fan at high RPM's to allow air through the radiator at higher speeds.
Just some ideas in case a new bottle doesn't do it.
