Elwood_Blues_
- Jacksonville, NC
Hey guys,
I've cruised the forums for a while, but never really posted. I'm looking at a 00 XJ limited. The Carfax says:
09/28/2006 Virginia Damage Report Accident reported Involving front impact It hit a sign or traffic signal
04/28/2007 Virginia Damage Report Accident reported Involving right side impact
It hit a motor vehicle
I didn't know that before taking it for a test drive. On the drive it seemed ok (mechanically) it did have what seemed to be a driveline vibe once I got on the freeway (roughly 60). I did some research and apparently the drive shaft can vibe even at stock heights. Pulling back into the dealership the oil pressure gauge dropped to zero, I wasn't worried about this either since I know they are a common problem on XJ's. But once I parked it to pop the hood and look into the engine compartment the passenger side hood release was stuck (the side with the reported collisions). Again, having not known it was in an accident before, I researched and found hood releases are fairly common and typically the passenger side is affected.
My question is how would characteristics of unibody damage manifest themselves while driving? Should I be concerned? or is it more likely that all the problems are indeed just the typical XJ issues...it does have 180k on it.
My reason for not just passing over this particular one is because my 99 has pretty significant unibody rust (from MN) so while I'm stationed in NC I'd like to get a clean one; and this one is VERY clean.
