mdicanio said:
I checked the manual and it definitely says Dexron. My BIG mistake! ATF+3 must not be that horrible since I have been running a mix of if it and Dexron for 100K. So what should I do? I really don't want to have a shop or the dealer flush it. Let me know your recommendations. Thanks. :sad1:
Don't be so hard on yourself, the dealer has resourses such as access to company service bulletins and is supposed to know better than the rest of us.
I'd confront him, you spent a lot of money on service, don't let be wasted.
Following are two service bulletins regarding ATF+4.
2100404 - AUTOMATIC TRANSMISSION FLUID USAGE ATF+4®
Date: 03/16/04 (supersedes 2100601 dated 6/29/01)
Model year(s): 1999-2004
Description: Information pertaining to automatic transmission fluid usage
ATF+4®.
Details:1999-2002 Grand Cherokee. A new transmission fluid (ATF+4® Type 9602) has been developed and is being used as factory fill for all vehicles with
Chrysler automatic transmissions. Until now, vehicles originally filled with
ATF+2 or ATF+3 were to be serviced with ATF+3. Effective immediately, it is
recommended that all vehicles with Chrysler automatic transmissions (except for 1999 and earlier minivans) be serviced with ATF+4®.
NOTE: ATF+4® MUST always be used in vehicles that were originally filled with ATF+4®. ATF+4® is compatible with ATF+3 and can be used to top off vehicles that currently have ATF+2 or ATF+3. DO NOT use ATF+2 or ATF+3 to top off vehicles that have ATF+4® fluid.
Benefits:
Better anti-wear properties
Improved rust/corrosion prevention
Controls oxidation
Eliminates deposits
Controls friction
Retains anti-foaming properties
Superior properties for low temperature operation
Fluid color:
Mopar ATF+4® is a World Class Fluid having exceptional durability. However, the red dye used in ATF+4® is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4® also has a unique odor that may change with age. With ATF+4® fluid, color and odor are no longer indicators of fluid condition and do not support a fluid change.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-006-01,
DATED JUNE 29, 2001, WHICH SHOULD BE REMOVED FROM YOUR
FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE
BEEN ADDED TO HIGHLIGHT REVISIONS.
SUBJECT:
Automatic Transmission Fluid Usage ATF+4 (Type 9602)
MODELS:
1989 - 1995 (AA) Spirit/Acclaim/Lebaron Sedan
1989 - 2003 (AB) Ram Van/Wagon
1989 - 1993 (AC) Dynasty/New Yorker/New Yorker Salon
1989 - 1993 (AD) Ram Truck
1989 - 1994 (AG) Daytona
1989 (AH) Lancer/Lebaron GTS
1989 - 1995 (AJ) Lebaron Coupe/Lebaron Convertible
1989 - 1990 (AK) Aries/Reliant
1989 - 1990 (AL) Horizon/Omni
1989 (AM) Diplomat/Gran Fury/New Yorker fifth Avenue
1989 - 2004 (AN) Dakota
1989 - 1994 (AP) Shadow/Sundance
1990 - 1991 (AQ) Maserati
1990 - 1993 (AY) Imperial/New Yorker Fifth Avenue
1994 - 2003 (BR/BE) Ram Truck
2004 - 2005 (CS) Pacifica
1998 - 2003 (DN) Durango
2002 - 2004 (DR) Ram Truck
1995 - 2000 (FJ) Sebring/Avenger/Talon
2000 (GS) Chrysler Voyager (International Market)
2004 (HB) Durango
1995 - 2000 (JA) Cirrus/Stratus/Breeze
2001- 2004 (JR) Sebring Sedan & Convertible/Stratus Sedan
21-004-04 -2-
1996 - 2000 (JX) Sebring Convertible
2002 - 2004 (KJ) Liberty
1993 - 2004 (LH) Concorde/Intrepid/Vision/LHS/New
Yorker /300M
2005 (LX) Chrysler 300/Magnum
2000 (NS) Town & Country/Caravan/Voyager
1995 - 2004 (PL) Neon
2002 - 2003 (PG) PT Cruiser (International Markets)
2001 - 2005 (PT) PT Cruiser
1997 - 2002 (PR) Prowler
2001 - 2005 (RG) Chrysler Voyager (International Markets)
2001 - 2005 (RS) Town & Country/Caravan/Voyager
1997 - 2004 (TJ) Wrangler
2001 - 2004 (WG) Grand Cherokee (International Markets)
1999 - 2004 (WJ) Grand Cherokee
1989 - 1995 (YJ) Wrangler
1996 - 1998 (ZG) Grand Cherokee (International Markets)
1994 - 1998 (ZJ) Grand Cherokee/Grand Wagoneer
NOTE: This bulletin applies to all transmissions manufactured by Chrysler except for 1999 and earlier minivans with the 41TE/AE transmission, This Service Bulletin DOES NOT apply to all AW-4 transmissions, Sprinter transmissions, Crossfire transmissions and WG bodies equipped with a W5J400 or NAG1 transmission (sales code DGJ).
DISCUSSION:
® - Type 9602) has been developed and is being
used as factory fill for all vehicles with Chrysler automatic transmissions.It is
recommended that all vehicles with Chrysler automatic transmissions EXCEPT
FOR THOSE LISTED ABOVE be serviced with ATF+4®..
NOTE: ATF+4
® must always be used in vehicles that were originally filled with ATF+4®.
NOTE: Service intervals do not change. The service interval currently in
effect for a given vehicle should continue to be followed.
