CFS 3 ROW RADIATOR
I've heard more complaints on one than positives!
I have a CSF 3-row out in the shed with 5000 miles on it .
It's yours if you want to pick it up.
It didn't work any better that the 16-year old, stock radiator it replaced.
It was replace with the superior Mopar 52080104AC, the best reasonably priced radiator I have found.
Electric cooling fans usually do not work nearly as well as the stock fan, as long as the fan clutch is in good shape.
Electrics have a lot more parts to fail, are more troublesome and are expensive if you use high quality fans and wiring. A new fan clutch every few years is a lot cheaper and less work
Electric cooling power isn't free, the alternator has to work extra hard to power them.
If you go this way, upgrade the alternator, for a longer service life and to keep the battery charged when crawling at low speeds.
