- Middle Tennessee
So Mark, what are you going to weld to it?
Nice!I've got my front 30 Alloy USA short side going on it and I've got my rear Superior 44 Alloy piece of shaft plus I have Dave's short side 30 shaft that the u-joint made fine work of. So, I will add two 30 short side shafts plus a piece of a 44 shaft.
Good fun!!!!!
Ok, after some thought...(yes it did hurt)...the SEC has hired James Earl Jones to make an announcement
Hasta
I would reconsider. I know you are running alloys but are they the bigger shafts with more splines?Well, maybe a 9".
come on now ghost... you arent going to break a 9" with 5.13s spooled and 35 splined shafts! on 35s!
The alloys I'm running are standard splines. I will probably end up with a spool in the rear though.
Looks like the 9" is pretty beefy!! What is the spline count on the 9"? Wouldn't it be stronger than the 44?
In all honesty I would try that b4 going to a 9" or a D60. Unless you get a tru hi 9. But that is some serious $$$$$$. I'd be intrested in the shaft size of the chromo D44's versus the 9" shaft though. You can build the 9" to 35 splines but you still loose 2" of pinion height.I'll probably go with 33 spline shafts in the 44 with a spool.
Yea, 32's that's the size!!
IMHO i would upgrade shafts and spool it.
Yea my boat does need an anchor!you guys should quit pussy footing around. 14 bolt.
