- Cheyenne, WY
The weather was perfect for wheeling. We ran down there for a shake-down run on a JK we've been working on for a customer out of Boulder. We got the rig after his former suspension failed on a JK run with Bob and some other guys. It was running a Teraflex kit until this happened.
The upper control arm mount tore right out of the frame on both sides. We've since fixed the frame replaced all the suspension with ours , installed an aluminum version of our JK modular bellypan system, reworked the steering and trackbar geometry and lowered the rig nearly 4" overall. In addition to the above it's running a Pro Rock D60 front, DynaTrac Full Float D60R rear, 41" Iroks, 5.7 Hemi, PSC ram assist and an Atlas t-case.
The rig performed beautifully and as you can see the aluminum bellypan held up nicely considering this JK weighs 6700 pounds.
Pat's not a big fan of being off camber, if you look close you can see the whites of his eyes sticking out around his glasses
