I'm new to the board and hope y'all can give me some of the same advice I've seen you've given to others. I've got a tired old 258 with a carb. I just lucked into a 4.0 from a wrecked 1998 Grand Cherokee. I want to swap it into my unit, but there's no way I'm ever going to get all the computer crap hooked up. Even my regular mechanic who normally will tackle anything doesn't want any part of it. So my question is this. Since I don't have any smog laws to worry about, what would be the pitfalls of dumping the FI and going with a carb. And if I do, what other mods should I make (I'm open to doing a cam, but don't want to tear down the engine beyond that). Also, I'm more interested in street performance, so I don't need all the low end grunt. I was thinking of a higher lift cam (any thoughts). Also, how much carb could I handle with this set up? And most importantly, if I go with the right carb, cam, and headers, how will my HP and torque compare to the factory 4.0 HO with the FI? Also, I was planning on using the trans from the 98. May be a dumb question, but will dumping the computer cause me any problems there? Look forward to hearing all your thoughts as I need to get this thing going asap. Thanks...
