- San Diego
I just went to a parts store and bought a second passenger side line. I dont have a reciept, but i doubt If it was more that 10$
I'd be looking at another $50 to buy a passenger side line, two hard lines and a bending tool, which I would inevitably screw up at least once.
I think the hose will be easier for me. If I don't like it, I'll change it out later.
Those shock mounts are not done well.
Shocks on an xj should be as far out on the axle as possible. Like / \
That will make it a smoother ride and maximize travel.
Use a shock mount that orients the shock perpendicular to the axle, not the way you have it. It will bind the way you have it
any particular reason you didn't fully weld the tube?
That would be overkill, and would add too much heat. You're just trying to keep the axle from rotating in the center section, a couple of stitch welds will do that.
For the ebrake I used 2 passenger side cables and criss crossed them above the axle then zip tied them up there. I believe I had to make the passenger side come up the body on the drivers side and vice versa. They fit right into the retainers on the body. The cable ends wouldnt reach the ebrake threaded rod so I pulled it from the console and added about 3-4" of rod on the end. Had to trim, I think, about 2 or 3 rounds of the spring on the axle end.
