- Desert Beach So Cal
Below is SB 708. This is a bad bill for anyone who owns an older vehicle.
This bill would change the law from vehicles being 30 years or older
to 45 years old to be exempt for smog testing. At the present time
if your vehicle is 1972 or older it is exempt. If this law passes it
would move it back to that the vehicle would have to be 1958 or
older. Call, write, fax or email you Senator and Assemblymen today
and tell them you oppose SB 708.
Thanks Don Klusman
BILL NUMBER: SB 708 INTRODUCED
BILL TEXT
INTRODUCED BY Senator Florez
FEBRUARY 21, 2003
An act to amend Section 44011 of the Health and Safety Code,
relating to air pollution.
LEGISLATIVE COUNSEL'S DIGEST
SB 708, as introduced, Florez. Air pollution: smog check.
(1) Existing law establishes a motor vehicle inspection and
maintenance program (smog check), administered by the Department of
Consumer Affairs and the State Air Resources Board, that provides for
the inspection of all motor vehicles, except those specifically
exempted from the program, upon registration, biennially upon renewal
of registration, upon transfer of ownership, and in certain other
circumstances. Existing law exempts from those requirements, until
January 1, 2003, any motor vehicle manufactured prior to the 1974
model-year, and after that date, any motor vehicle that is 30 or more
model-years old.
This bill would delete the exemption for those motor vehicles, and
would instead, commencing January 1, 2005, exempt any motor vehicle
that is 45 or more model-years old.
(2) Existing law makes any violation of the smog check program, or
any order, rule, or regulation of the department adopted pursuant to
the program, a misdemeanor.
By expanding the scope of a crime, this bill would impose a
state-mandated local program.
(3) The California Constitution requires the state to reimburse
local agencies and school districts for certain costs mandated by the
state. Statutory provisions establish procedures for making that
reimbursement.
This bill would provide that no reimbursement is required by this
act for a specified reason.
Vote: majority. Appropriation: no. Fiscal committee: yes.
State-mandated local program: yes.
THE PEOPLE OF THE STATE OF CALIFORNIA DO ENACT AS FOLLOWS:
SECTION 1. Section 44011 of the Health and Safety Code is amended
to read:
44011. (a) All motor vehicles powered by internal combustion
engines that are registered within an area designated for program
coverage shall be required biennially to obtain a certificate of
compliance or noncompliance, except for all of the following:
(1) Every motorcycle, and every diesel-powered vehicle, until the
department, pursuant to Section 44012, implements test procedures
applicable to motorcycles or to diesel-powered vehicles, or both.
(2) Any motor vehicle that has been issued a certificate of
compliance or noncompliance or a repair cost waiver upon a change of
ownership or initial registration in this state during the preceding
six months.
(3) (A) Prior to January 1, 2003, any motor vehicle
manufactured prior to the 1974 model-year.
(B) Beginning January 1, 2003
2005 , any motor vehicle that is 30 45
(4) (A) Any motor vehicle four or less model-years old.
(B) Beginning January 1, 2004, any motor vehicle up to six
model-years old, unless the state board finds that providing an
exception for these vehicles will prohibit the state from meeting the
requirements of Section 176(c) of the Clean Air Act (42 U.S.C. Sec.
7401 et seq.) or the state's commitments with respect to the state
implementation plan required by the Clean Air Act.
(C) Any motor vehicle excepted by this paragraph shall be subject
to testing and to certification requirements as determined by the
department, if any of the following apply:
(i) The department determines through remote sensing activities or
other means that there is a substantial probability that the vehicle
has a tampered emission control system or would fail for other cause
a smog check test as specified in Section 44012.
(ii) The vehicle was previously registered outside this state and
is undergoing initial registration in this state.
(iii) The vehicle is being registered as a specially constructed
vehicle.
(iv) The vehicle has been selected for testing pursuant to Section
44014.7 or any other provision of this chapter authorizing
out-of-cycle testing.
(5) In addition to the vehicles exempted pursuant to paragraph
(4), any motor vehicle or class of motor vehicles exempted pursuant
to subdivision (b) of Section 44024.5. It is the intent of the
Legislature that the department, pursuant to the authority granted by
this paragraph, exempt at least 15 percent of the lowest emitting
motor vehicles from the biennial smog check inspection.
(6) Any motor vehicle that the department determines would present
prohibitive inspection or repair problems.
(7) Any vehicle registered to the owner of a fleet licensed
pursuant to Section 44020 if the vehicle is garaged exclusively
outside the area included in program coverage, and is not primarily
operated inside the area included in program coverage.
(b) Vehicles designated for program coverage in enhanced areas
shall be required to obtain inspections from appropriate smog check
stations operating in enhanced areas.
six months.
(B) The department, by regulation, may increase the exemption
provided by this paragraph to include any motor vehicle up to six or
vehicle.
SEC. 2. No reimbursement is required by this act pursuant to
Section 6 of Article XIII B of the California Constitution because
the only costs that may be incurred by a local agency or school
district will be incurred because this act creates a new crime or
infraction, eliminates a crime or infraction, or changes the penalty
for a crime or infraction, within the meaning of Section 17556 of the
Government Code, or changes the definition of a crime within the
meaning of Section 6 of Article XIII B of the California Constitution.
Thanks Don Klusman
BILL TEXT
FEBRUARY 21, 2003
model-years old.
reimbursement.
to read:
six months.
vehicle.
six months.
vehicle.
