With bigger tires they look great & help keep the windows clean.
Yeah they suck to put on. Yeah they can fall off, unless you stay off the trees. Yeah you will have to modify them for your rear bumper or use the excuse to get a better bumper and get rid of the plastic end caps. Yeah you will have to remove metal to or past your pinch seam & weaken the body some unless you weld it back together.
I have been wheeling with mine through brush & up steep offcamber hillclimbs where they rubbed the wall. They are still on there, maybe the posers didnt get them installed correctly? lol!
I think they look good..Im running into the same problem.....A little trimming goes along way.....Even if you didnt like them you need them in Pa these damn cops nail ya for 2 inches out over!!
I found that the nuts that hold the factory flares on are the same size as the bolts that hold the BW flares on. So I just backed up all the BW bolts with the factory nuts and some washers and have no more problems with tearing off the flares.
