Bunch of cherokee parts
DunkinDeezNutz
Boston, MA
Bunch of stuff pulled from my 98 XJ two door, 4.0/aw4
If you don't like the prices make me an offer
located in Stow, MA
hit me on here or text nineseveneight-8two1-threenine78
Front wiper motor $40.00
Complete steering column with shaft and wheel with all switches, will break up if need be $150.00
Hood $120.00
Steering box $60.00
Crossmember $40.00
Rad Support $30.00
intake manifold $50.00
Napa replacement Radiator, less than a year old $60.00
AC condenser OEM $50.00
Prop Valve $20.00
Master Cylinder $40.00
Idler pulley with tension screw and bracket $40.00
Coolant overflow bottle $10.00
v8 ZJ steering box with cherokee diaphragm swapped ready to bolt in $60.00
power steering lines in good shape $30.00
header panel, some damage on left and right sides, text for more pics $30.00
Hand brake assembly $30.00
Glovebox $30.00
Fan shroud $20.00
Pass side tail light $20.00
PDC with all working fuses and relays $60.00
Rear shaft, joints in ok shape $50.00
For some reason picture captions aren't showing up on tapatalk so I will list the part/price below. Also I accept cash or credit card thru my iPhone with PayPal here app/card reader. I can ship on buyers dime as well
Front Wiper motor $40
Complete steering column/intermediate shaft/steering wheel $150.00
Hood $120
Steering Box $60
Crossmember $40
Radiator support $30
98 Intake manifold $50
One year old Napa replacement radiator $60
AC condenser $50.
Proportioning valve $20
Master cylinder $40
idler pulley w/ tension screw and mounting bracket $40
coolant overflow bottle $10
v8 ZJ PS Pump ready tol bolt in XJ $60
PS Lines $30
Header panel $30
Glovebox $30
Fan Shroud $20
Right Tail light $20
Rear Driveshaft $50
More Parts
More Parts
Dash Frame with airbag $100
HVAC box with working heater core, blower motor, all wiring $140
Engine management harness $100
Stock airbox $20
27lb thrust Minn Kota transom mount trolling motor $60
